Old 07-14-2023, 01:47 PM
Area Man Area Man is offline
Default 2166 PTO issue
Hi,
First time poster here. I own a 2166 with about 850 hours, well maintained.
We have had a ton of rain in my area this summer, and I had to delay my last mowing until things got pretty thick. About halfway through the mowing, I noticed that the discharge chute was clogged (but the blades were still spinning and cutting as normal). I shut it all down and cleared out the chute. I also made sure the deck was clear and the blades could spin freely. When I started the machine back up, the PTO would not engage. I just get a little 'pfft' sound when I pull the PTO knob.
Is there some kind of safety switch I may have tripped?
Other facts that may be relevant - Fact 1 - The battery is pretty weak, and I have been using my emergency jumper to start the motor lately. But even when it's really dead, the PTO has still worked just fine. I actually tried jumping while pulling the PTO, but this didn't work. Fact 2 - The previous owner disabled the reverse-gear PTO safety shut-off, so that it will mow in reverse. Again, I have never had an issue with the PTO in two years, so this is not a top candidate.
Thank you for any insight you may have!
Old 07-14-2023, 01:53 PM
Inactive Member
First, welcome to OCC..........
Replace the battery with a new one, of equal or better CCA's.
Old 07-14-2023, 05:37 PM
CubDieselFan's Avatar
I have seen people break their tractors when they keep trying to use it with a dead battery. This will cause the stator to burn up. It is trying to charge a bad battery and keep the pto on at the same time and that lets the smoke out of the stator.
Old 07-14-2023, 05:40 PM
Some info from Taryl.
https://www.youtube.com/watch?v=E-X9_yviL_8
Old 07-15-2023, 04:02 PM
Pulled the battery and got a fresh one today. The last one only made it through two summers, which makes me think there's a root cause that a new battery won't fix long-term.
Thanks to all for your input!
Old 07-15-2023, 04:13 PM
If it is one from wally world, I am not surprised.
Old 07-15-2023, 08:35 PM
Ozcub's Avatar
Ozcub Ozcub is offline
If it is a lead/acid battery it will not last as they get shaken to bits , you need either a gel or calcium battery to last in a ride-on
Oz
Old 07-19-2023, 06:12 PM
I replaced the battery with a brand new upgrade, and it did not fix the problem.
Where should I look next? It still makes a slight 'pffft' sound when I pull the PTO knob.
Old 07-19-2023, 06:52 PM
Inactive Member
Sounds like a bad PTO Switch.
Old 07-20-2023, 03:37 AM
Oak Oak is online now
Do you have the wiring diagram for your tractor? Do you have a digital volt meter?
If you don't have either of these you will need to get them. I(or Roland) can email you the wiring diagram. Digital meters are cheap.
