Kohler 20 HP Horizontal engine
I have a GTX2000 with the 20 HP horizontal shaft engine. It has about 296 hours and uses a quart of oil every time I mow my yard, about 2-3 acres, an 1 1/2-2 hours run time. Does anyone have or had one of these engines and have had this problem? The warranty had just expired when I had to have both cylinder heads repaired. Is the Kohler the piece of junk someone told me it was? HELP?
I do not think that 20 hp Command is junk. Sounds like you have a head gasket issue. An engine expert will be along shorty. What did they repair when it was under warranty?
My Cub had just gone out of warranty when the engine problems started. I needed the mower to be in working order and the dealer I bought it from said they were covered up and it would be 5 weeks before they could get to it. I took it to a local tractor dealer and repair shop and go it fixed.
So what was wrong with the heads when it was fixed?
The valves were messed up. First one head. Then a month or two later, the other head messed up.
I picked up a 2550 a couple years ago that had the same issues. What I found out was that the screen on the flywheel was plugged so it overheated. Thing got so hot that it melted the hood. Pulled the engine cleaned it up, replaced both head gaskets, extended the exhaust and then sent it down the road.
Will replacing the head gaskets stop the engine from using oil? Not an engineman, I'm an electrician.
Are you killing the local mosquito population?
Leaky head gaskets can cause a Command to use oil if they leaking in the right place.
