I'm working on a front manual PTO
First of all, I must say this site is awesome. Thank you all.
I picked up a questionable 126 about a month ago, along w/some interesting PO mod's. 1st I rebuilt the carb to see if the K301a was good. I got it running w/a knock, then noticed the front pulley was loose, so a new keyway was in order. Tuned it up, adjusted the valves, trued up the head w/a new head gasket, went thru & cleaned up the brakes, wire brushed the deck & replaced some bearings, made new baffles, then paint, fixed the wiring along w/a new volt reg. So now it runs good, w/a very small amount of blowby. Again, thank you for having all this info so handy. Now for the PTO, The 1st time out w/the 126 I noticed the blades were slowing down in heavy grass. I pulled the type "A" pto & disassembled it. The clutch is cracked & the pressure plate & the pulley side are pitted. I'm thinking about machining these surfaces & has anybody just flipped the pressure plate over? Then all I have to do is get a clutch kit. Here some pics for your enjoyment.
126 72fj40,75fj40 |
Looking good!
Looks good! Thanks for the pics.
What is the black paint you used on the underside of the deck?
I used a big cupped wire brush on my big grinder to knock down the surface. Then I used rustoleum rust reformer & gloss black. On something like this I like to apply 2 coats w/a brush. I found this holds up well, & my high pressure washer won't peel it off. The deck was pitted on the bottom, but still pretty solid. I hate to say it but...The top got gloss white, it was what was on my shelf.
126 72fj40,75fj40 |
I took my front pulley & pressure plate to a friends, he basically has a machine shop in his garage. We chucked up the pulley into the lathe & cleaned up the clutch surface. I would have thought the pulley was cast steel, but its not. Its cast iron. There was no real good way to put the P/P
on the lathe, so we used the surface grinder to true it up to a point. I got it home & was able to get it much better. I used a large flat file making sure to keep it flat on p/p surface & rotated it every so often. The file will show the untouched low spots. When I thought it was getting close I lightly painted the surface w/primer & did the 220 grit sand paper on glass trick as shown in the tech section for head gasket replacement. The low spots will still have paint. I repeated this several times. When I was getting real close, I put down the file & went w/150 grit on glass, paint,220 grit, Repeat. There is 1 low spot, my .0005 feeler gauge wouldn't go under a straight edge. I did this to the back side of the p/p, the used side was just too pitted. I ordered parts today, hopefully I have results by the end of the week.
126 72fj40,75fj40 |
Well after some shipping snafu's I finally got my parts, set up the PTO & installed it per the service manual. I have since cut the grass several times & attacked some heavy tall grass & the blades never even thought about slowing down. All is good. I wanted to make sure I finished this post w/the results. I don't know how many times I've searched on various subjects on projects I want to do & end up on an informative thread & at the end of it the OP says "I'll let you know how it works" & never replies back. This seems to be one of the most common problems w/most websites similar to this 1. It just drives me nutz. The main issue I found on this site, is the search function doesn't reconize 3 letters or numbers. So searching for PTO & 3 number CC models becomes difficult. Anyways, all is good & thanks again for such a great website. Ken
126 72fj40,75fj40 |
Glad you got it fixed!
