Options?
My 1872's m18s has a Walbro 52 053 51 on it that started acting up. I took it apart to install a kit, found that the float had gas in it and replaced that, too. If I hold the carb inverted, I can't blow through the fuel supply line, which made me believe the seat was alright. However, it is still somehow leaking. Doing a search for a new carb makes my head start swimming, as one site's discontinued number leads to another. Can someone tell me where I can get one?
I am 94.2% positive you can put a carter/kohler #26 carb on an m18. Cub N boxers has one listed for sale, might need to put your choke arm on if the homemade one does not line up.
http://onlycubcadets.net/forum/showthread.php?t=42987 Bill |
Look for a carb off a Kohler kt 17, it will bolt right on and has the adjustable needles. I run one on my m18 in an 1811 and it's great.
Most times just a needle, or needle and seat will stop the leak, not a bad $10. investment.
https://www.smallenginesuppliers.com..._TP-2377-E.pdf shows the same numbers for the K17 and M18, so I can see how they would bolt right on, but that doesn't help me find one. According to Brian Miller's site 47 853 23-S is the Kohler OEM, which I can find, can anyone confirm this? |
Was it a plastic float?
If it was metal, you have to adjust it to the correct height..... |
Try this place for Walbro parts
http://vepetersen.com/ They are a Walbro dealer--give him the make and model of the carb and let them do the rest. Sounds like you are just out of adjustment though.
And yes, the float is plastic and adjusted correctly. (parallel) |
The carb for the kt 17 has a metal float and replaceable seat like the k series carbs.
