Question regarding the big one, the Kohler K 341
Greetings- Currently own an Original, a 102 and a 122 (oh, and a 1320 that I will be selling soon)and have my eyes on a 149 that might need a motor. I have a good running Kohler K341 motor that I grabbed out of an Allis Chalmers 416 last year. My question is about the "charging system" on the 16 HP motor. If it has a built in stator, does it (the stator) have to be removed or just disconnected to work properly in a 149? Is there a code in the engine tag that would let me know what's under the flywheel, or should I just remove it to check for myself? (just to be thorough). Currently the motor has a bendix type starter and a toothed flywheel.Thanks in advance for your insight. regards, Paul, Providence, RI
You can also pull the flywheel and remove the stator coil.
I must be missing something, if it has the bendix style starter why would you want to disable the charging system? Why not use it as is?
That's what I was thinking, the block probably doesn't even have a spot to bolt the s/g bracket.
In my non professional opinion I'd rather rewire the tractor than deal with a starter generator. A wiring harness for something like a 1210 and it's good to go. Just my 2 cents.
The 416 uses the wide base oil pan and will not fit without mods to the mounts.
What type of base does this block have? It may not fit anyway. A wiring harness from a QL will substitute. I can't think of any reason why a AQS motor won't go into a 1X8/9 frame. Basically the same frame as a QL. Only thing I can think of is I believe the engine in the 1X8/9 sat into the frame a little lower. Might have clearance issues with the starter. I'll have to look. |
I too would recommend changing the wiring rather than changing the engine over. |
