Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 10-06-2014, 07:06 PM
woodbywallace woodbywallace is offline
Default Flywheel removal
Looking for any instructions on the best way to remove the flywheel so the oil seal could be replaced on rear seal. sure am learning a lot from this fantastic site. The info given here is great, and are highly appreciated Thanks so much Big John from Derry Pa
Old 10-06-2014, 07:14 PM
TheSaturnV's Avatar
It would really help to know what motor you are working on. Always include anything you can about your tractor, motor and so on when asking for tech help.
Old 10-06-2014, 07:39 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
T bar puller, harmonic balancer steering wheel pullers both work. a hammer and a big prybar works to but don't break the stub that the nut goes on off the crank if you use that method
Old 10-06-2014, 07:48 PM
There's threaded holes in the flywheel for puller bolts to go in, I believe they're 3/8 x 16 pitch. As Don said a T bar puller one of the ways. You can look in the K series manual in the tech section and there are pictures and listings of special service tools
Old 10-07-2014, 01:08 AM
bocephus1991's Avatar
T bar puller and a impact wrench work best, it can be done with a 1/2" breaker bar.
Brian
Old 10-16-2014, 12:40 AM
81warren 81warren is offline
Default Take off flywheel
Few have a suitable puller, here's how I got the flywheel off my Kohler 14hp: Find a short 5/8 " NF bolt, also a nut to fit the same. Screw the nut onto your shaft using only half of the threads, then screw the bolt into the nut and tighten. This is what's called the poor man's 'knock-off' block, you then stick a sturdy screwdriver in behind the flywheel to put outward pressure on it, hit the end of the bolt with a good sized hammer. Mine came off on the second blow.
Pullers and special tools are best but this works quite well.
Also, welding the nut to the bolt at half threads makes a permanent 'knock-off' tool, I keep mine in the special tools box.
Warren
Old 10-16-2014, 01:47 AM
Warren
A puller is less likely to bend the end of the crank. Again, this way works, but it's easy to screw up the crank this way. A puller isn't expensive. Way less than a crankshaft.
Old 10-16-2014, 08:34 AM
You can get a puller like this.
http://www.amazon.com/Sunex-3900-Ste...3459105&sr=1-3
Old 10-16-2014, 10:02 AM
I use a cheap $12 harmonic balance puller and a wack it with a rubber mallet. Never had one not come off yet.
Old 01-29-2015, 08:21 AM
CubCadet129 CubCadet129 is offline
I used a puller like oak has and just be careful to use the right bolt and correct thread and don't brake off the Bolt in the flywheel!!
