Help needed
Hi,
This winter I purchased a 1989 Cub Cadet 1050 with a broken driveshaft. This week I replaced the driveshaft, couplers, throwout bearing, hanger and bracket, clutch, clutch drive pins, and pressure plates. I got the driveshaft and couplers from "Jeff" These parts work great! What I didn't bargain for is that second gear is banging and jumping, I think second gear must be missing some teeth on one of the gears. Can any of you lead me in the right direction sourcing the parts needed to repair second gear, and give some insight to the repair itself? Thanks, Pickle |
What model tractor is it?
Try the Cub parts site.
http://www.cubcadet.com/webapp/wcs/s...00505_-1_image http://www.cubcadet.com/equipment/AR...______________
Link for the service manual.
http://www.onlycubcadets.net/forum/s...ad.php?t=25397
Unfortunately from what I hear that's a common problem with the trans they put in that model tractor, you would probably be better off installing a cast iron rearend out of an older cub and then you never have to worry about it again.
Thanks for links to the information. Does any member have a set of gears stashed away under a bench they would like to part with?
The guts of the cast iron and aluminum trans are the same. Be careful, there are 3 different 2nd gears. Make sure you get the same tooth count as the one you have. Have you opened it up yet to see what is actually bad? If not, do that first before buying parts. Without looking I think the 1050 used the 19 tooth second gear.
Check with the sponsors above to source parts. Other good places include ihccw.com (has gears in stock), and ebay. |
will a cast trans from a 128 work in a 1050? I was thinking I had read somewhere the driveline angle had changed at some point, but dont remember exacty which trans was being talked about.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
I'll try to get it apart on Monday - we've had a cold snap here and I don't want to work in the garage when it's below freezing temperatures outdoors.
I can't get the service manual to load enough pages to learn about the differential/transmission, slow mountain dialup service around here. |
