782D / 882 radiator finally blew! Any chance of a replacement?
Searched the forums.....nothing.
Has anyone replaced your 782D or 882 radiator? Thanks for any help. |
$669.28 new from Messick's.
What actually happened to your radiator? It may be possible to repair it.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck |
I damaged a radiator on my cr125 back when I was in high school. Had it fixed pretty cheap. When I got it back it had a small square missing in the middle of it. Looked a little odd, but never had a problem out of it.
i would think a radiator shop could recore it for less than 670$ i would think... have seen a few rads on epay lately is a 2086 with a kawi even close?
http://www.ebay.com/itm/Cub-Cadet-20...item35e59cf230
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
Where did it blow out?
Sorry, not too thorough on my info. It developed a pretty good leak a few months back, large enough that the rad would empty while sitting still...took around an hour. Took it to a shop, and they repaired it but weren't making any promises on how long or if it would hold. I bet I got just an hour or two since then, and it's now leaking just after shutdown but doesn't empty out.
I'll probably take it back to them, but thought I would check here to see what the options are. I've wondered if the same radiator is available under another PN or application. I know lots of sailboats use the Kubota D600, but my boating website was a strikeout. |
Most all marine engines just pull sea water for cooling.
I've not looked close @ a cub radiator in person, but my local radiator shop can repair/re-core any radiator as well as make custom ones.
I would think possibly another shop could take care of your problem, if the previous repair folks can't take care of the problem, or contact our sponsors or check out ebay. |
However, I will say that I have seen radiators that the copper was corroded/rotted and too thin to repair. But they were extreme cases. Most of the time they can be repaired. The reason that it's hard to get radiator shops to do this is because most of the time, the radiator can be replaced for less than the cost of the repair. That is not the case with this one. |
