LT 1050 PTO Install Problem
I have an LT 1050. When the drive belt broke I had to remove the PTO to replace the belt. When I reinstalled the PTO the connection wires broke because the PTO was not secured. What holds the PTO in place to prevent is spinning? There does not appear to be any metal shaft that the PTO locks into. The parts diagram shows a "metal bracket" that has a 90 degree bend and an angled edge. If the PTO is held by this bracket then where does it bolt to the frame?
