Replacing PTO switch on 1772
Gents: 1. can’t figure out how to get the old switch out. Do I need to remove the dash?
2. Does anyone have directions for replacing the front PTO on same machine. Thanks much…long time Cub owner. Currently have 2 1872 and 1 1772. |
First, welcome to OCC...........
The 925-0893 PTO Switch is held in place to the dash panel with a Hex Nut that you can see from the operator's seat. Once you have the replacement switch, loosen and talk off that nut, change out one wire at a time, then reverse your steps. The Front PTO is held on on the engine with a nut & washer on the end of the crankshaft, and 3 to 4 bolts holding it to the engine crankcase. Remove the nut and mounting bolts, unplug the wire(s) and pull forward.
