Old 06-13-2018, 01:11 AM
jjardina jjardina is offline
Default Headlight Question
Will IH CC 126 headlight assembly fit on a 128? For that matter, are 1xx lights interchangeable?
I'm looking around and see complete headlight assemblies for a 126 and other 1xx models, but they didn't specify 128. I don't know if it would fit on a 128 or what lights would?
Thanks for any helpful responses.
Old 06-13-2018, 01:18 AM
No.
They are two different series. The series is NOT 1XX, it is 1X6/7 and 1X8/9.
So headlights from a 73, 106, 107, 126, 127, 147 are all the same. (73 is part of that series.)
In the next series 86, 108, 109, 128, 129, 149, 169 are all the same. (The 86 is also part of that series.)
The 1X6/7 series is a narrow frame series, the 1X8/9 series is a totally new tractor series and went to a wide frame.
Old 06-13-2018, 01:20 AM
Awesome answer! Thank you!
Old 06-13-2018, 08:07 AM
IHCubCadet147's Avatar
You might be able to make your own panel. You just need good measurements or one to use as a pattern. You would still need the lights though.
I made the one for my 147(which is different than yours). Someone gave me a 149 panel, and I used the lights from that and made the correct panel. Yours should be easier because it's flat, no bending or welding.
