Picture of the Week: August 7, 2015
This weeks submission is sent to us by local member WCompton aka Wyatt Compton. Wyatt comments "Here’s the 2072 I refurbished. It was previously owned by the Rudd Rockford Marble Rock school in Rockford, IA for its whole life, used to blow snow from the sidewalks and maintain the ball diamonds. I took the liberty of restyling it to look like what IH may have produced should the line not have been sold off to Modern Tool & Die. The graphics are closer to the Super 70 2+2’s graphics than what the TRX concept tractors had. This was done just by using stripes from a 128/129 decal kit, and having the numbers I designed made from duplicate material. The grill was custom built from material that matches material IH used on other grille screens, and the lights are glass housings from a DF1073KB driving light kit, with LED lights (though I’ll be going back to Halogen 35w H3’s soon, as the performance of the H3 LED units is poor). The grille is still retained with the stock springs for easy access to the PTO. The machine still retains its Magnum 20, upgraded with a #30 carb, a tremendous improvement over the Walbro. The original aluminum rear end has been upgraded with a cast iron housing, but retains the stock fine spline axles, carrier, etc. A Ruegg 3-point kit that replicates the original with PTO provision has been added. The OEM 8.5” wide rear rims were replaced by 10.5” rims with parts from Miller tire, and have Titan Tru-Power II rubber. The rear “cast centers” are just starter weights for a Deere 400 with an extra set of holes to place 6 bolts evenly spaced (painted IH non-glare black, of course). Rear tail lamps; since they're the same part as the rear markers for the Vega/Chevette/Astre, I just simply used the amber front marker light housings, with LED lights and an EP27 flasher to mimic the hazard lights that the full-size tractors have." Thanks for the submission Wyatt!!!
Note: Picture is scaled down to fit here, for full resolution image simply click on the picture below
-Ryan
Awesome! That's exactly how I am going to paint my 1211 and turn it into a 1282. May make it a 1288 now! Very nice work on the grill! Looks like factory OEM! Congratulations on potw! Very cool super! Where did you get the material for the grill?
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
VERY NICE!!! We need more pictures!!
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
I agree, more pictures! Can you give me the the size or gauge of the perforated metal for the grill? Again Very nice 982 !
That tractor is absolutely awesome! X2 congrats
Only a 1282 with ~700 hrs(serial 729357)... Just red and black and ain't goin back! |
I can't quit looking at your tractor!! The red paint, the grille and the decals are absolutely awesome!!
Id love to see some detailed photos of the grille and how it was made PLEASE!!!
Very interesting mods, and congrats on POTW
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
Thanks for the kind words!!
With regards to the grille: As far as the grille material, if you check out McMaster # 9255T62, you'll find a perforated material that matches the OEM screen of the upper headlight panel (as well as 5488 grilles). I'm lucky enough to work next door to a hot rod shop where I took the screen over and had three ribs rolled in the screen. It was then bent down the center and affixed to a formed 1x1 steel frame. It attaches just light the original for easy access to the PTO. The headlight panel is just 16ga with formed buckets for some 3 x 5 Blazer (brand) driving lights. It attaches with the three holes cast into the grille (tapped 5/16" coarse thread), the top fastener is a stud with a spring so that the headlights can be aimed up or down. The badge is just an original 82 series badge with the red and black portions masked off and painted IH aluminum. http://www.onlycubcadets.net/forum/a...1&d=1439209720 |
Here's another picture from a couple weeks ago when I was heading out to plow.
http://www.onlycubcadets.net/forum/a...1&d=1439211491 |
Sweet looking machine.
