Another question
I am thinking about putting a toggle and push button on my 1450. Has any one done this? How would I wire the toggle and what type do I need?
Jim Bridgewater, KD0FJO Osage, IA 1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow |
toggles
I did it on a 1250 years ago trying diagnose a problem. Find a 10 amp toggle, feed it from the + side of the battery thru a fuse and hook it to the wire comeing out of the electric clutch.
I assume that you plan to eliminate the standard Ignition Switch with your plan.
Problem is.....that the Charging Circuit is wired through the Ignition Switch and is turned on/off with this switch. Now you can do what you are planning, but extra modifications and switch(es) would have to be wired to accommodate the Charging Circuit.
