Old 09-14-2013, 12:21 PM
Inactive Member
Default Mis-Fire
I have been chasing an intermittent spark problem on my KT-17 on one of the cylinders, More failure than working right.
Turns out, the the metal wire end connector, up inside the boot, was "rusty". So, a soaking in "the Works" toilet bowl cleaner, rinsing and neutralizing the acid, blow it out real good, pinch the connector together for a better grip, and Wha-La.........I have a good spark now.
Now, who woulda thunk..???
Old 09-14-2013, 12:26 PM
After this many years, anything can happen, my 1000 was hard to start, ran rough,
the condenser wire had slipped out from under the nut of the coil connection.
Who would of thunk it EVEN would have run, at all!!??
Glad you were able to find it, Roland, corrosion can be difficult to find!!
Old 09-14-2013, 03:41 PM
Glad you found the cause of your problem! Ya, I've seen that many times before, on a lot of different engines.
Similar story to CAD's: Had a 1974 C/60 Chevy grain truck come in one time. Suddenly started running rough. Started checking things over, couldn't find the source. Was sure it was in the ignition system, but couldn't find anything wrong. Decided to replace the points or clean them or something..... anyway, upon trying to remove the condenser, found out that the bracket that held the condenser to the point base had broke and the condenser wasn't mounted to anything. New condenser, FIXED! So, you never know. Some of the hardest problems I've tried to find, had the simplest solutions!!
Old 09-14-2013, 04:33 PM
cubby102's Avatar
cubby102 cubby102 is offline
Or something as simple as my dad wanting to get his generator tuned up and running before winter he pulled on thag thing for a couple hours and it wouldn't start. He forgot that there was a fuel shut off in the tank. Also the low oil sensor wire had been knocked off
1872 - 60"haban 54" power angle haban blade
'63 Original - restoration project
582 -tiller
147 - leaf duty with bagger.
1811 - Ditch mower
800 - have it just cuz its a 800
Old 09-14-2013, 04:35 PM
Glad you found the problem, Roland!
