Old 01-29-2014, 09:58 PM
dagwoodz dagwoodz is offline
Default Coarse spline help
What are all the tricks to keep my coarse spline rear from breaking till I get a fine spline together? How do I strap the carrier? Does gun drilling the axles help? I am pulling a 12hp unlimited rpm (steel flywheel and billet rod) with 23 inch cut tires.
Old 01-30-2014, 05:32 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
you can wrap the carrier with a piece of 1/8 steel or find a tube to fit over it. years ago I'd drill and tap the center pin on each end and bolt heavy flat washers to each end. even if you get the carrier to stay together you still have to deal with the axles twisting
