LT1045 Parking Brake hard to engage
A few years ago, my parking brake became hard to engage. I step on the foot brake and then try to push down on the lever to engage the parking brake but it is hard to get to go down. If I rock the mower a bit while doing it, it helps but doesn't always work either. Sometimes I have to move the mower forward a little and retry it. I eventually get it, but it seems something is not quite lining up for it to easily engage. What should I look for to fix it?
2008 Cub Cadet LT 1045 Manufacture date: 2/20/2008 Kohler 20 HP single cyl. Twin cam OVH Model SV600S Spec No: SV600-0009
2008 Cub Cadet LT 1045 Manufacture date: 2/20/2008 Kohler 20 HP single cyl. Twin cam OVH Model SV600S Spec No: SV600-0009 |
Sounds like a linkage issue.. Get down and look under it.
Seriously. You mean this fat old man has to get down on the ground again?
I hate it when that happens.
In order for the Parking Brake to engage, the hydro control (fwd/reverse) pedal must be centered. If it's not centered, then you probably need to adjust linkage. Also possibly have broken/missing spring or issue with centering adjustment on transaxle.
