Old 07-10-2021, 08:42 AM
cturboaddict cturboaddict is offline
Default XT2 LX46 Fab Deck PTO will not Engage
So, I had an intermittent issue a couple years ago when my 2017 XT2 LX46 FAB wouldn't engage the blades. I took it all apart, and it worked fine.
Mowed 2 weeks ago, no problem.
Went to start this week, and mower fired up fine. Blades would not engage.
Then I started blowing the 20amp fuse under the seat when the PTO switch was activated (no PTO operating).
I replaced the PTO switch (although tested fine)- Nothing.
I have no power to my red wire on my switch.
Tested resistance of PTO clutch at 3.2. - Good
Replaced both reverse and brake switches (although tested fine) Nothing.
What am I missing? I cannot find a 2017 wiring diagram, only a 2015. The 2015 notes a PTO relay..... But I cannot find it....
Does anyone know where I can find a 2017 wiring schematic?
Does anyone know where the PTO relay is? If there is one?
Old 07-10-2021, 09:33 AM
Inactive Member
The Factory Model should be: 13WQA4CN010
I looked and can't find a diagram either.
Old 07-10-2021, 12:20 PM
Here is the serial number.
13AQA4CN010
Old 07-23-2021, 09:44 AM
Default Fixed
Hopefully this will help someone down the road.
I checked ALL of the safety switches. (Seat, Reverse, and Brake). All tested fine, replaced anyway. Tested the PTO switch- tested fine, replaced anyway. Tested the single relay strapped to the side of the engine- tested fine, replaced anyway. Tested PTO, tested fine/actuated fine.
Called cub cadet and after getting someone competent, they send me 3 pages of wiring diagrams. 2 were accurate for my XT2 LX46 fab deck with the Kohler engine and push button start. The other one had some additional wires.
I found the Push Button Ignition Module was not getting Power out to the PTO. Everything else functioned. Ordered a push button start ignition module and Wala. Fixed.
Old 07-23-2021, 09:52 AM
Sorry you replaced so many unneeded parts to find the problem.
Just goes to show it is so necessary to diagnose/trouble shoot a problem, not shotgun parts at it.
Good thing is you have spare good used parts, and you posted back to help others.
Thank you.
Old 07-23-2021, 10:39 AM
Thank you.
Parts were cheap. The Module was not. If I could of gotten a diagram that would of helped. I can't figure out how to upload the PDFs to the site, or I would.
