Obscure new one...1986 1914 Super Cub Cadet
This guy followed me home last night. Homeowner said it needed a starter or solenoid, but it cranked when I put the Noco on. New battery and it'll run on ether.
I have the carb soaking now...it sat for 7 years, and you can tell.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
It has the 986 model code. I had hoped to find a 3 point and rear PTO in back, but only the front hydraulics exist. No PS either, so this is about identical to my 982 (984 code) minus the fact the dealer swapped this back to a Kohler engine (appears to be a KT17, will confirm tonight).
According to the CCC feature guide, the 1914 (986) should have had all the features ie: Dual Hydraulics, Rear PTO, and 3 Point Cat 0 hitch.
Maybe someone took them (rear PTO & 3 PT) off, prior to your ownership.
Looks like a good deal there... was it local?
I thought about looking at that one, but the no power steering kind of ended it for me. Didn't he advertise it as having a Command swap?
RUN IN THE RED 782 w/50c deck (red); 782 dual stick, 44c deck (y/w); 1050 w/38c deck; 1864 w/54" GT deck; 1872 project Cub Cadet Pro Z 560 L 42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper 1200, 1863, 1864 parts machines |
What model would have had front hydraulics but no rear pto or 3 point?
$300 & about 35 min away. Poplar Grove.
He said Kohler v twin but as soon as he opened the hood I knew it was a KT17 or M18. It's certainly a KT17 and I doubt *it's a series II but haven't proven yet it's a series 1.
That was a steal! Not many of these were built.
Check this out, mine was 4 down on the line than yours was. DSCN3864.jpg It should have the a hole in the tunnel cover for the PTO switch like this as all 1914's came with an Onan B48G, front remotes, rear PTO & cat 0. DSCN3853.jpg
