Old 11-06-2010, 03:09 PM
redcubbie redcubbie is offline
Default 782 oil leak
Working on a 782 w/kt17 kohler that leaks a little oil while running. Seams to be coming from behind the clutch in the front. What kind of project will that be to fix? Anything to be aware of digging into this?
Old 11-06-2010, 04:04 PM
Not bad...just have to remove the PTO clutch and change the crank seal, and clean everything up while you're in there.
Old 11-06-2010, 08:41 PM
Can I safely assume that I can get the seal needed at my local cub dealer?
Old 11-06-2010, 11:15 PM
Yes, you can.
Old 11-08-2010, 09:48 PM
OK guys...need some help here. Cub Cadet dealer I talked to today said he wasn't aware of two different seals like I read about on this website. Does anybody know the correct seal number that I need for this KT17. How do I tell the difference between series 1 and series 2.
Old 11-08-2010, 09:57 PM
Inactive Member
By the Spec Number.
Series I =Spec No 24299 & under
Series II = Spec No 24300 & higher
Old 11-08-2010, 11:30 PM
I guess I'm out of luck because I can't find the spec or serial number decal on this motor. Anybody have any suggestions?
Old 11-08-2010, 11:33 PM
It is on a tag under the intake manifold on the left side of the engine. It's just to the left of the fuel pump.
Old 11-08-2010, 11:57 PM
I thought that was where it was supposed to be, but nothing there!!
Old 11-09-2010, 12:11 AM
Well...if you have a series I, it should have an adjustable carb and a metal pipe plug for the oil fill. Series II has a non-adjustable carb and plastic cap for the oil fill. A series II may also have an oil filter blockoff on the right front side of the engine. If you have a flat, box-shaped air cleaner housing, it is most likely a series I. A series II will say "Series II" on the flywheel shroud and air cleaner cover. All bets are off if somebody's been swapping sheetmetal, though...
