Mule Drive Question
Are the pulleys on the mule drive supposed to be the same distance from the front of the tractor? Im new to the cub cadet facination and need to learn all I can. Thanks
no, they aren't. sombody with more knowledge will most likely post a link to proper tension
Tyler Chiliak. Southeast Alberta Canada. My dad and I own, 1650, , 1450, 1250, 1250, 1200, 982, 782, 149, 149, 149, 128, 128, 123, 100, 100. Also a 1310, 1500, and 2 1600 IHC trucks. |
Mine are an inch or so from center with eachother IIRR more or less. No not neccessarily. As long as the belt is tight and the pulleys are clear I'd not worry about it.
Scott |
If you go to the tech library you will find the topic with pic [posted by our own R Bedel.
To improve belt life, a proper alignment from the PTO drive pulley to the center pulley of the deck is imperative. Also, is it important to use the correct belt.
Every time I find the key to success, someone changes the lock |
Ah yes centered under the engine pulley but the tension pulley will not stay aligned to eachother, as least mine don't, allows for movement.
Scott |
PTO belt streched ?
or wrong one.
not sure if its streched but looking at the front of the tractor, the pulley on the right has an adjustment bolt and the one on the left looks to be a lever and that one is set back further than the one on the right
OK we need to call an expert in or a reasonable facsimile .
Help !! I know of the lever your talking about , It should have two notches one to remove belt the other is a gauge to replace belt., in between those notches the tension should be adjusted so pulleys are inline with the PTO belt should run as streight as possible as not to prematuurely whare out
ok so i was under the tractor last nite at midnight and noticed that the pulleys were severly offset! The pulley with the treaded bolt is fubared. looking at the belt, it looks like its the wrong size. it is rubbing on the spring that is attached to the pulley bar. what size belt do i need and can i get the bolt that holds the pulley in place from a local hardware store or does anyone have one laying around that they wouldnt care to part with?? the bolt looks like it has just a hook on the end that goest to the pulley bar thanks for all your help.
