782 engine transplant?
Can any of you tell me if a 15 hp engine out of a 1541 will work on a 782? My 782 broke a rod. It had a Kt17S engine type II. The engine from this 1541 looks to be about the same. I have only seen pictures. The replacement engine even has the external oil filter, which I would consider a plus. If any of you have any knowledge regarding this possible transplant, I would truly appreciate your input. Thank you.
You indeed can. It's basically a M18. It is a bolt in engine. All you have to do is do a minor wiring change. I would post how to do it but i'm not at home right now.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
Thank you very much AJ for the post. Was the news I was hoping to hear. Now I need to see if I can get it bought and hopefully hear it run. Will let you know if I get this together and if I need help in the wiring mod.
Thanks Again, Roger |
Just make sure you use the spacers under your old engine with the new engine for proper alignment.
Got the engine bought, now I hope one of you, A.J. or anyone else can tell me what the wire modification is about. I probably won't do any work on it till this weekend, so not in a great rush.
Thanks Roger |
Roger
You want to talk to the Master of Cub Short Circuits the one and only Dr.Roland Bedell. He will want to know the serial # of your tractor and then the magic will begin.
CCC built 782 Sr#2050601u714340
Conversion Diagram. I hope you can read it.
AJ
Thanks Guys! Wish me luck.
Rog |
How did this turn out for you? Got a larger copy of this?
Thanks! |
