CH20S into a 682
This may need moved...
I am looking at a CC with a CH20S and power steering. wanting to kwo if both will bolt in a 682. Appears the motor will. Can't tell what model this machine is though to research the PS. https://drive.google.com/file/d/0B7P...it?usp=sharing |
Engine will go but not a bolt in. PS will be a project.
The motor should with little modifications. The power steering, I doubt it. I don't think any of the 682's had a ported pump.
I have a 1250 ported for parts that I plan to make it a 782. That is if I ever get my shop built to make room. The fact the engine will fit inside the panels is promising.
Plenty of room under the hood for a CH. If I was doing the swap I'd look for a motor plate and a muffler from a Cyclops. I'd make a drive shaft from a 2000 series. Holler if you need help.
Reading on here that dual stick units are somewhat rare?? And kinda hate to cannibalize it. Is complete minus one side panel. Plus appears the cylinder is different that a 782.
There aren't many parts between the QL series that will work on the '82 series. Trans is same, I believe the front axle and maybe the steering shaft, that's about it. If you have a dual stick, I'd keep it. If you don't want it let me know! I have no ideal how I would get it.
Interesting, Distance is always a challenge, but we might be able to score a deal. About the only thing I see I can use is the ported pump, valve assembly and hard lines to the front. Regretfully i recent pulled the engine out so is in pieces but all still there. Engine ran but did smoke. Although might have cleaned up with use.
I have a similar deal with a 147 that I need to send on its way. Suppose it is time to post the add. Would love to see them go to a good home and not scrap. |
The hydraulic valves are the same, but the lines are different. The front remote outlets on a QL ran down the left side of the frame, but on the '82's they ran down the right side. PM Sent!
