Kohler rebuild Questions
Hi Everyone, I just had rings put into my kohler 321 for my 1450. I noticed that with the new rings the piston is stifer and harder to turn over. Is this an issue or is it normal. Thanks in advance Timothy
That's normal...it'll loosen up as the rings seat.
Thanks for the reply, this is the first set of rings i've ever put in. i've always been lucky and only had to grind valves on all my other engines.
Did you get the end gap on the rings correct?
