Old 11-10-2016, 10:14 AM
Default 169 issue
Hey guys,
I was driving the new 169 and I noticed the amp meter shows it is discharging, it still starts fine, but when I give it plenty of throttle and push the hydro lever all the way up the tractor sometimes slows down to a stop, then goes faster when it idles, could the charging issue cause this and is it the s/g? Thanks
Old 11-10-2016, 10:54 AM
RustyYellow RustyYellow is offline
The engine showing a discharge isn't why you're slowing down, they are 2 separate problems in your case.
Either the battery is showing signs of wear and has a cell that's bad and drawing current from the other cells, or you have a bad regulator or your s/g is having problems.
Each item needs to be checked/tested to eliminate, if that's where your amp showing discharge is coming from. It could also very well be a bad amp gauge if all other tests show good.
I've had new batteries get bad cells, so you need a load test done to see if a cell has gone bad.
The trans sounds like it's low on fluid and as it heats up and oil thins, the pump can't draw the fluid to operate properly. Check the fluid level and check for leaks as to why it's low. Relief valve(s), gasket/shaft seals, hose/metal line nut needs tightening. If the trans or pump is wet/shiney, you have a leak.
'67 Cub Cadet 102 w/Kohler 10
'90 Kut Kwick CL20-60 w/Onan 20 Performer
'03 Craftsman GT5000 w/B&S 24 ELS
Old 11-10-2016, 11:23 AM
Have you changed the fluid and filter yet?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-10-2016, 11:32 AM
Terry C's Avatar
Terry C Terry C is offline
Step one on a tractor with unknown maintence.
So when you say it slows down you mean just forward movement, or is the engine slowing along with it? It's not bogging down right?
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-10-2016, 11:42 AM
The battery is brand new, the engine does not bog down, the tractors speed just slows down, there are no leaks, I have not yet changed the Hytran and filter, I have a new cub cadet filter for it, the Hytran is at the right level and looked ok, but the filter is original from what I can tell, so I will start there, but the amp gauge goes toward D, sometimes in the middle, but never to C I'm pretty sure.
Old 11-10-2016, 12:37 PM
kalebevans kalebevans is offline
On my 169 the amp meter always shows a discharge. When I first got it running I though it was discharging and messed with a whole bunch of things trying to figure it out, but I found that it just reads to the negative. If I turn the lights on it moves down and reads even more negative, and when it is charging it almost reads at the center. I don't know if you've got a bad one like mine, or if they are adjustable, but for now I just try not to look at it too much because it bothers me. It's kinda like the gas gauge in my truck- it can drive a hundred miles before the needle gets down to 'full', and the last quarter tank seems to disappear after about ten miles.
169 with tiller, 50C mower deck, Earthcavator, 42" front blade, Brinly tt100 toolbar, and QA42A snowblower, and now an Original!
Old 11-10-2016, 04:35 PM
cubs-n-bxrs's Avatar
Why don't you put a voltmeter across the battery leads and see what it is actually reading. If it's discharging do the S/G test in the tech library and see if it's a voltage reg problem or the S/G. Really doesn't get much easier Nick.
Old 11-10-2016, 04:37 PM
Did you try switching the leads on the amp gauge? Maybe someone hooked it up backwards.
Old 11-10-2016, 05:44 PM
Thanks for the advice Kelly, I'm not that good with electrical but I happen to have a rebuilt spare s/g to try.
Old 11-10-2016, 11:47 PM
Nick, why mess around changing things if they aren't bad. Just do as Kelly said, then you'll know. You can figure out, red goes on possitive, black on negative...
