Old 09-22-2012, 01:04 AM
backswampcub backswampcub is offline
Default 100 Deck question
My 100 has the 3 spindle cast end deck. The Idler puller is just bolted down to a long slot. But when I look on part diagrams it shows a idler arm piece that mine does not have. How should the idler puller be attached to the deck. Thanks for any help
Old 09-22-2012, 01:35 AM
lonnyb's Avatar
lonnyb lonnyb is offline
There are many different decks that can be swapped between narrow frame cubs.
Some are as yours is with the slot, others have the idler arm that is spring loaded.
Old 09-22-2012, 01:53 AM
From what I could see on parts tree, with the idler arm which has a spring also, but the arm is n/a. I've got an old deck out back, if no one answers you question by tomorrow I'll look and take a picture for you.
Old 09-22-2012, 08:24 AM
Mine has the long slot cut into the deck. But like previously mentioned on parts tree it shows that slot but also shows the arm. I am asking because there is a NF Cadet at a lawn mower junk yard and I need to know if I should get the idler arm off of it or just stick with the bolt through pulley method.
Old 09-22-2012, 10:08 AM
Inactive Member
You will have to check with Cub Cadet if parts are still available, but here ya go....
Old 09-22-2012, 12:41 PM
I know what the idler pulley arm looks like. But in some pics of the early 3 spindle decks it appears as if the pulley is just riding in the slot on the deck. But later ones had the arm. I was trying to find out what was the proper way it was supposed to be mounted.
Old 09-22-2012, 01:04 PM
Inactive Member
The above image IS of the early deck.
Old 09-22-2012, 05:49 PM
On a cast-end deck, the idler pulley goes in the slot. I think they may have decided that wasn't the best idea later on and changed it to the spring-loaded type all of the later decks have.
Old 09-23-2012, 12:27 AM
jdroison jdroison is offline
Thumbs up
I have 2 old decks, one has the slot and one has the spring. they did change to the spring on later ones
Old 09-23-2012, 05:45 PM
Well the 129 Hydro I was going to pull the idler arm off of was picked cleaner then a turkey carcass on thanksgiving. It was a complete tractor just a week earlier. I did manage to get a rear hitch and light switch off of it. I will just use the slot.
