1860 engine not centered
OK, this has been bugging me for a while now on this project I am working on. The engine on this 1860 sits 1/2" more to the right of center of the frame. You can see it in the driveshaft too. I took a picture of the right side and the left side, the engine hangs over the right side of the frame and sits inside the left side? What gives? I don't see anywhere that you can adjust the mounting left or right. I guess I can just weld in the engine mount holes and redrill them?
This is the way it was when I got it, I noticed it right away but thought I could live with it but I can't It isn't the engine tin, I checked that.
Chip T. Drexel NC |
You know, I never did look at where the mounting pan bolts to the frame, is there room there to move the pan left or right?
Chip T. Drexel NC |
I believe they are all that way. Or at least all of mine are that way. I've been kind of courious as to why they are all offset.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
