Old 05-26-2013, 07:29 PM
vartz04 vartz04 is offline
Default honed and reringed k241 Running hot
Just got my tractor running again and it seems to be running extra hot. Is this normal or what should I check into?
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 05-26-2013, 07:40 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
did you readjust the carb after the rering? got your ign timing and governor set correctly? about the only other things that will cause it to run hot are plugged cooling fins or excessive friction. now that being said new rings are meant for a round bore. not an egg shaped bore. so until the rings wear into the egg shaped bore there's more concentrated pressure in small areas of the rings and bore
Old 05-26-2013, 07:44 PM
I've been trying to tweak the carb. Gotta grab t he timing light from my dad and check that out too.
Old 05-26-2013, 07:54 PM
dvogtvpe's Avatar
you should be able to check it staticly with a test light or spark tester
Old 06-12-2013, 08:56 PM
Still seems to be hot. Or gets hot very quickly. I've got the carb tweaked and used it a total of about 3 hours so far. Anyone have a temp gun and could check their cyl head when there engine is hot.
