Had better days with the 2372
Don't even start hacking on me. I feel bad enough already. NO ONE WAS HURT, in this catastrophe...
Just wanted to post, hoping no one will ever have this happen to them. And the worst part, well, maybe not the worst, think the tractor took the blunt of the worst. But this all could have been avoided, IF I would have used new prevailing torque lock nuts throughout. Yeah, I used one older nut on the driveshaft flex disc joint, instead of all new one's. Why? I wish I had a good answer, call it lazy. Too lazy to go to town for one nut. I had three new one's, and that was it, so... Installed a new driveshaft last week that my machine guy up here made, as my other one was worn out a bit on the ends. That all started when I needed to replace the seal on the pump, then noticed the driveshaft was in poor shape, so get a new one. Haven't dug into it yet, that'll happen another day. So if anyone is replacing a driveshaft, OR anything in that area, don't reuse the nuts. This could be you... Anyway, here's a few pictures of my mess. And HOLY COW, did that SOB make a racket when it let loose. Almost scared the chit out of me. The 1650 is going back on lawn duty for awhile. Cause this repair is going to take me awhile.
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
Ouch! I'm glad you came out ok, I'd hate to think what a heavy shaft spinning at ~3600rpm between my legs could do to my...southern region in the seconds it'd take to turn the machine off.
-Ryan
Holy Mother Mary Todd, you are one lucky sob to still have your marble sack. Glad you didn't get hurt. Sorry to see you have a little work ahead of you. Good the 1650 gets to stretch its legs tho!
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
Glad your OK. Cub doesn't look too bad considering what happened.
The damage is UNBELIEVABLE! I am glad you are ok.
Queen Of The Quietlines! |
Holy crap!!! Sure wrapped that hydraulic line up. Glad no one was hurt.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights. {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
Dang Todd, that SOB tore some chit up! No one got hurt, that's the main thing. Good thing to have a nice backup grass cutter. Did it just grenade all at once?
I do have a question about what type of nuts to use. I use the grade 5 nylon lock nuts and grade 8 bolts from TSC and I think I put a dab of blue Loctite on them. Is it okay to use them in that application? Here is what mine look like. DSCN3239.jpg DSCN3238.jpg
Sorry to hear about the mishap Todd, I am sure it will be tended to in due time.
Oak, I use what cub cadet used, worked for them.
Dang Zippy that's some carnage going on there. Glad you are OK. Never seen chit wound up around the driveshaft like that before.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
Yikes is all I can say. I've been using over the locknuts if I didn't have new ones. Pretty certain I have been using the kind with the dimple in the side. I need to check some of my stuff and make sure all is tight.
Sorry about the mower, but glad you are OK--that's the important thing!
