Old 02-29-2016, 09:24 AM
SGragg SGragg is offline
Default 782 Starting Issue Solved
Removed the 782 starter last weekend after diagnosing inconsistent starter performance. Removed starter, disassembled, cleaned and reassembled. Ran out of time last weekend to reinstall, but got it in yesterday.
What a difference!
Now, the starter kicks over each time (like it's supposed to). Finished up with new points/condenser, plugs, fuel filter, fuel tank shutoff, oil and air filter. Installed the deck and took it for a practice mow.
Works great!
Old 02-29-2016, 01:40 PM
Glad to hear it!
Old 03-01-2016, 12:56 AM
Congrats on the repair...
Old 03-04-2016, 09:26 PM
bugzilla46310 bugzilla46310 is offline
What all did you do to the starter? My 782 is just spinning without engaging. Engages about every 20th time. Seems like I cleaned it about 3 years ago to " fix" it. Been starting to act up since last fall. Only start it every so often as my blade is on my other garden tractor and the 782 sets most of the winter.
Old 03-04-2016, 10:25 PM
Take the starter off and apart, clean it inside and use fine emery to clean the end commutator, check the brushes for length, replace if necessary, lube the bushings with light weight oil.
A few drops is sufficient,more is not better, reassemble and clean the helical spline and relube with 52-357-01 it costs about $4 and is what works best @ all temps.
Reinstall/enjoy.
All this is covered in the overhaul manual
Old 03-06-2016, 04:19 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
YAY!!!!! or... WOW <- glad you got it fixed cowboy
1- 1200 in pieces
1- 1864 in pieces
Old 03-06-2016, 09:37 AM
john hall's Avatar
Reinstall/enjoy.
Never knew such a thing as Bendix drive lube existed. Is it similar to never-seize? That I have on the shelf. Knowing my luck if I tried to buy some I'd have to order a case or pay $15 freight.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 03-06-2016, 11:55 AM
RLause's Avatar
RLause RLause is offline
Partstree has it.
Kohler Engines 52 357 01-S
LUBRICANT, BENDIX STARTR
Your price: $4.61
Richard
Old 03-06-2016, 02:55 PM
Last tube I got on evil pray was $5 delivered.
Anti-Sneeze dries up and causes the gear to be sticky on the shaft after a while.
Considering the starters are not a simple R&R, might as well use what ya posta, and not look back
Old 03-06-2016, 03:09 PM
john hall's Avatar
I'll look into getting a tube to have on hand. I would say we never have starter trouble, but that would be jinxing things, or lying, or both!
2072 w/60" Haban
