Cub wheel weights on a 782-bolt size?
When mounting Cub wheel weights on a 782, what size/length bolts have you guys used?
2005 CC GT2544 1980 IH CC 782 1957 Cub Lo-Boy 1993 Craftsman LT4000 |
That would depend on the Brand Name, and weight of the weights you are installing. I used 1/2" x 5" Carriage Bolts for my Bolen Weights.
6" should be fine.
Roland, they're IH Cub front wheel weights/Cub Cadet rear wheel weights.
Thanks for the responses guys.
Regardless, it is a simple measurement. Use 1/2" Carriage Bolts.
I have the CC 75 pound (basically plastic buckets filled with cement) weights on my cyclops. I used all thread with two nuts hold it to the wheel and then the weight and washers/nut to hold the weight on. my 782 had carriage bolts but they are soooo hard to mount without using a nut to hold the carriage bolt to the wheel and running a nut down the 6 inches of thread is very time consuming.
