Mag 18 starter problem
The wife's 1812 starter just spins and wont engage. It was fine till it got cold out. I'm thinking it was lubed or oil or something leaked onto it and is gummed up or just stiff because of the cold temp. Will cleaning and lube help this? Or, should I change out the drive gear? Which brings me to next part of question. Partstree calls for part number 82-755-32. The cheapest one on epay is 59 bucks, half of cub cadet's price. If you search for "kohler starter drive" there's all kinds of kits for $20 bucks and all the pics look the same. Is there really that many different ones?
Has anyone else had this problem and what was your remedy?
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
My suggestion to you is, order the part(s) you want and be "part number specific". Do NOT order by images, or this is what it looks like. A lot of sellers use images as "general reference" and it really means nothing.
In my world, I would pull the starter out of the tractor. Take to the bench. Dismantle the "bendix drive". Clean it all up, lubricate it, then re-install. Now, if you want to spend as little time as possible and assure yourself a positive outcome, order & install a whole new starter.
Roland is on the mark here...I have fixed many "bad" starters just by taking them off and cleaning the internals...You would be surprised how much debris gets inside of them...Plus it just costs you time the first go around...
cool thanks guys
Another possibility.
Put a charger on your battery for a little bit. That will put more kick in your starter to spin the drive out against the flywheel. I've had Magnum starters act like that. I think I've just sprayed brake cleaner in around the starter drive and that fixed it. For now. I remember also taking one apart as suggested above and cleaning it up. That fixed it. I've never seen the need to buy a new starter. |
