Old 08-02-2023, 09:10 PM
Tom Dowling Tom Dowling is offline
Default 682 ignition switch problem
My 682 ran fine when parked ( where have I heard that before? ) Now when I try to start it it dies as soon as I let go of the key, could the ignition contact be bad? I turn the key to start and it starts and dies when the key is at run.
Thanks for any help.
Old 08-02-2023, 09:50 PM
Inactive Member
Replace the Ignition Switch (725-3021).
Old 08-03-2023, 07:17 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Common to have corroded/burnt terminals/plug at the rear of the battery/ignition switch. Remove connector, inspect for defects, clean and reinstall. See if it works. If not, replace the switch with a correct switch made for point style ignitions.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 08-03-2023, 09:15 PM
Thank you all I'll give it a look and report back
Old 08-06-2023, 04:42 PM
Yes it was corrosion at the ignition switch, I cleaned the contacts and she started and ran fine. Thanks for the help. I'm surprised it corroded since it's stored under roof.
Old 08-08-2023, 07:24 AM
1711Cub's Avatar
Lightbulb
That is a design flaw with these Cubs. There is a great deal of current going through those small terminals. The least bit of corrosion begins and then resistance, and with that comes heat, then melted connectors, then open circuit.
