Old 07-14-2020, 12:56 PM
12johndeere 12johndeere is offline
Default Kwik way backhoe
I am looking for any info on how the hydraulics are done with a loader and pump size, reservoir etc. Any help would be great.
Old 07-14-2020, 05:27 PM
Shall we guess you are wanting to put this on yer 12 HP John Deere Lawn tractor??
Old 07-14-2020, 07:29 PM
Heck no, getting fitted to a 318, but searching the web hasn't turned up much info. So I am reaching out. I found a brochure that says this was intended for a cub cadet. Hopefully someone here has come across one
Old 07-14-2020, 08:41 PM
Not trying to be mean but a three minute search found:
brochure stated this is more of a universal backhoe.
the mount kits (52-#####) specific to each brand/model determines which tractor or the universal mount (52-01100).
it stated "backhoe mount kits have been designed to attach to the subframe of the K-W loader and use the hydraulic systems built into the loader" you may need the mount of the loader to fit the backhoe in addition to its pump and reservoir
I saw bolens, JD, mitsubishi, snapper, ariens, cubcadet, etc.
K-W loader reservoir is filled with 6.5 quarts and the "304 pump" has part number 100943.
Put on your big boy pants and look a little harder! haha
Old 07-14-2020, 09:20 PM
Can you post where you found that please. Thanks for the pump info.
Old 07-14-2020, 09:25 PM
Did you get that from the brochures on Ebay? I couldn't make out what they said .
Old 07-14-2020, 09:45 PM
I dont want to break any rules here so do a google search for 5210-loader-kwik-way-fel-45-17710 for the manual in pdf
and then do another for Picked up a Kwik-Way Loader for my 522xi
you're gonna have to figure out the pulley ratio to get to the correct speed on the pump
Old 07-14-2020, 10:20 PM
Thank you for your help
