Torque wrench
While filling out my Christmas list it occurred to me that I do not have a torque wrench. I'd be using it on my cub (head bolts, rear end bolts, etc) and I'd like it to be a craftsman. What should I be looking for? From an owner that has never owned one....thanks.
Daniel G. . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
If you get a "click" type, make sure you back it off to the lowest setting when not in use.
I have both a click type in 1/2" drive and a beam type in 3/8" drive. |
I would go for a 3/8 click type first, that will cover 90% of what you need. You will never justify the expense of an electronic type, (I'm a pro heavy equipment mechanic and I cant). I doubt that you will use a 1/2" much, not a lot of bolts that require accurate torque of 200 ft/lb on a cub.
The theory on torque is simple. tight's tight, too tight's broke!
"If I can't fix it, I can screw it up so bad no one else can either" |
I have both the half inch and 3/8ths inch click type. As well as a "beam" type 3/8ths and honestly I don't think I've ever had to use my half inch on a cub. But I work on bigger things as well. As with any tool you get what you pay for also
1872 - 60"haban 54" power angle haban blade '63 Original - restoration project 582 -tiller 147 - leaf duty with bagger. 1811 - Ditch mower 800 - have it just cuz its a 800 |
I have all types of torque wrenches. From a 1/4" 10inlbs min, to a 3/4" 600ftlbs max. I have both digital, and "click" type. Craftsman makes a 3/8" click type that will suit you well, and the price is moderate. I agree, you don't need a 1/2" drive, or a digital. Honestly, a beam type is pretty accurate, and they never need calibrated.
Digital w/preset beep tones are cheap, I've seen them on the truck for around $600.00, Now how often do you use one?
I use my digital all the time. But it also has the option of doing degrees, inlbs, ftlbs. I have the 1/2" drive Snap-On digital. Beeps, vibrates, and shows the torque and degrees as you are using it. It's a pretty cool tool! |
I got one from sears for $39.00 for black Friday
I have the bigger ones that are in foot lbs. but I like the 3/8 drive I picked up thats reads in inch lbs most torqu specks i see are in inch lbs.
Doug Original / IH 70 / IH 149 / IH 1650 / IH 582 / CCC 1772 West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
Thanks guys. A backyard mechanic who doesn't work on things for a living the advice helps. Now don't get me wrong I'm mechanical in nature, been tearing into stuff since I was little, but not much experience with a torque wrench. Knew they were needed on CC heads however. I "ordered" both the 3/8" click Craftsman type in foot and inch pounds.
