Wheel weights
Has anyone had any expierence with xtreme motor works wheel weight adapters? Wonder how much total weight you can accumulate. I have some weight lifting weights collecting dust An rather have wheel weight vs chassis weight. I understand 10lbs plates or under are the max diameter you can fit.
It would take an awful big stack to equal a good cast wheel weight. The IH ones are kind of puny in my opinion at 25#. There are lots of others that fit. I have a later set of 75# CC wheel weights that do me well. I also put liquid ballast in my tires. That's where you get real weight.
Welcome to the forum! |
Thanks I'll keep an eye out for the cast weights!
If you pour about 8 gals in the tire you'll add about 70lbs. per tire.
