2182 altenator output
Hello,
The alternator on my 2182 is putting out 37 ac volts at WOT, is this correct or is this why my regulator seems to be kaput? Seems like they're usually 28-30 volts? |
It's a hi dollar Fluke DMM, so hopefully it is accurate. The DC volts out of the R/R is only battery voltage (12.3), measured across ground and red wire, I believe that should be the charging wire. But I checked the others and I'm only getting battery voltage. I Guess I'm going to try a new three wire R/R.
The last 2182 that I had I replaced the Kubota VA with a Kohler VR part # 41-403-10-S
Check and clean all the electrical connections between the alternator and regulator before replacing parts.
Under what conditions are you measuring the 37 VAC at WOT? disconnected from the battery? At the input of the regulator? The Kobota voltage regulator has a built in voltage reference source that limits the output and shuts down the output to stop charging once the battery is fully charged. So, if the 37 volts is measured at the input, while the output is about 13V then you are ok. The regulator will be shut off and not allow additional charging of the battery. The Kubota regulator is not a simple rectifier. I have an internal schematic of it around here somewhere if I can find it.
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
Sorry, typo meant to put in 14 V
Offhand the only item I can come up with right not is from the IH servive manual. It states.... Alternator no load output AC volt or more @ 5200 RPM @20 volts.
Voltage Regulator Regulating voltage 14 to 15 Volts
