Compression Release Problems....
Bought a new pulling cam from Vogel. It is the 4K welded cast cam. Stock lift just alot of duration.
It has been a pain to get it to start easy. I had problems getting the valves correct. Now the spring on the compression release is slipping off and causing the ACR not to work. It will work proper for a few starts then it starts to crank very slowly. When I first had the problem I noticed the spring was all bent up. (maybe damaged it during the install) Had a stock cam and removed the spring and installed it on the new cam. Ir worked fine for a while. (maybe 8 starts) Now it is hard to start. My valve last is @.011 on the exhaust and @.009 on the intake. What would cause the springs to bend while installed on the cam? What will cause it to come out of place as well?
Operation Iraqi Freedom Vet!!!! |
I would call Chuck and ask him those questions.
Larry Cub Cadets -- 124, 129(149) with loader, 1000 V-twin puller, 1650, 2165, grandson's 72 |
