Old 03-20-2024, 07:49 PM
FlatBar's Avatar
FlatBar FlatBar is offline
Default Need help with haban 60" mower on a 2086
I have a 60" haban mower on a 2086 that is not mounted correctly. The center pulley on the deck rubs on the right side of the lift frame. I know I could shim with washers and bend stuff, but I feel certain the mower was not mounted correctly.
The v shaped plate that you can see in the first picture is not right. It does nothing but rattle. I am surprised that it has not fallen off as it is not attached to anything. Any help would be very appreciated as I should have already mowed the grass.
Old 03-20-2024, 08:58 PM
garydee's Avatar
garydee garydee is offline
I'm wondering if you have the inner frame and deck hangers mounted in the opposite holes of the outer frame. Try mounting the inner frame to the outer frame using the center holes. The lift hangers would then be attached using the front holes on the outer frame. Not 100% sure as I am not very familiar with your deck.
Sam Mac would know for sure...he knows just about everything there is to know about supers and Habans!
Old 03-21-2024, 05:56 AM
Well for starters part # 2 is on backwards. Item circled in red. Also check to see if the rear mount on the deck is cracked or bent, the Haban's have a bad habit of breaking the rear mounts. Pics are of one that I fixed up. It had been bubble gummed by a PO. Re-welded and braced, no more problems.
On another note take a good look at the bolts that attach the rear end to the frame, the Supers are notorious for breaking the bolts and the front mounts. I strongly suggest you get a set of rea rend braces from Xtreme https://www.xtrememotorworks.com/Rea...d%20Parts.html
Old 03-22-2024, 09:18 AM
garydee's Avatar
Sam Mac to the rescue again! Thanks for the valuable information.
