IH Push Blade Facelift
Started the push blade facefift today.
There wasn't a real good spot on it other than the blade itself. Cut, gring and weld, then grind some more Also ground off the extra brackets the PO welded on, and removed the bent mounting pin (if that's what it is called) Would anyone know the measurements of the original mounting brackets? Picked up a couple grade 8, 3/4" bolts to make a new mounting pin,
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
Looking good! I love how old crap metal can be cut out and nicer stuff patched in, then painted and it doesn't look like it was ever any different.
Daniel G. . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Looking good Todd!
Todd, you always do awesome metal work. That thing will look like new when you are done with it!!
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
Great job, Todd!
Great work sir!
Thanks guys, appriciate it.
Got a few more things done today. Got the grade 8 bolt head cut off and welded in, I welded washers on the inside for a little more meat so to speak Also got the goobered up mounts cut off, man that sucked. Anyway, does, or can someone get me a measurement for the front hangers, and the size of the quick pins? Thanks
Keep up the good work, Todd!
Anyone help out on a measurement?
PLEASE
What type of tractor is it going on? I've got a NF blade that will fit a 1X4/5 and 1X6/7 series and do not mind measuring for you.
