Quick attach three point.
I'm sticking with the quick attach theme on my 1772. I'm in the process of finishing up a cat 0 3 point hitch. the hitch plate attaches with only 2 pins and two quick connect hoses. I removed the hydraulic cylinder for the mower deck lift (don't plan on ever putting a mower on it) and installed 2 longer hoses to reach the back of the tractor. They hook up to the new lift cylinder for the 3 point. I still have a few loose ends to tie up, probably try and find a spot to put some suit case weights too, and paint of course. ill update when its complete. then it will be time to make some implements.
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
Nice job, Ken!
Looking good Ken!
That is sweet! You rock!
thanks guys!
question, the max hydro pressure on the supers is around 900 psi right?
My manual says 500-625 PSI. I emailed you the Hi Rez pic.
Great job!
Bill |
500-625, i thought that was for the GTs? ok it is what it is.
with a few calculations, 550psi should net me 389lbs of lift at the lift arms and 216lbs of down pressure. not too bad.
There is a guy on YouTube who has a heavily modified 982 (runs on propane) and he said he got more hydraulic pressure out of the pump by shimming it....not exactly sure how how it's done or where to look but you could contact him rough youtube and I'm sure he'd explain. Just look up 982 on YouTube and you'll find one of his videos.
ill have to check that out.
im going to check the pressure of my pump to see what i actually have.
