1772 lift problem
It seems (and I am not sure why or what changed becaused everything was working fine) that my lift lever is now hitting the upper edge of the opening in the dash not allowing the linkage enough travel to push the valve in to move the cylinder. I tried to move the valve up on the steering column but it really did not move too much. It seemed to be limited by the solid lines going down to the steering box not sure if they should move up or not. I diconnected the linkage and pushed the valve in to see if lift would move to rule out other problems and it moved fine. The only thing I discovered was the nuts that hold the lever bracket to the side of the tractor were not real tight so I tried to realign to get more travel but was unable to do so. I need help plow day is coming up.
Charles________________________ 1572 3pnt, rear PTO, 50" deck 1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow 1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow 2072 3pnt 50" deck, Brinly Plow 2072 50" deck Cub Cadet Tank 50 Zero Turn Cub Cadet 33" Commercial Walk Behind 1953 Ih Cub with just about every implement New Holland TC33D with Loader and Backhoe |
Any chance the whole steering column dropped down? Maybe the lever twisted or it's worn?
Levers seem to be ok. not sure if colunm dropped but I am not sure how to raise entire column.
Loosen the U-Bolts on the valve spool base and slide the unit up. I'm sure that is your problem. Yeah, it will move hard, and you'll really have to pull because of the steel lines, but it will move. Good news is it really won't have to move much to make a big difference.
Any good way to do this I tried to pry up and evidently was not successful
Can you get a jack under the valve?
I will see when I get home today
adjusted lever bracket and got it working
Make sure your holes in the lift lever are not "wallered out" causing lever slop too.
