Old 12-12-2014, 12:03 PM
darryljs's Avatar
darryljs darryljs is offline
Default Winch setups (request by garnold)
Originally Posted by garnold View Post
Any chance we can get you to show both of these winch setups in the attachments sections. I'd like to see how you made that plow setup. How is the speed on this? I plan to add a spring assist to my tractor. I've heard from some folks that the winch is kind of slow and not great if you need to lift/lower the plow often.
This is the way I set up my winch to be universal. I used what I had on hand at the time , which was 3/4" pipe, 1/4" plate and 3/4" bolt. Cut plate to size to mount winch and welded pipe on edge. For the trailer, plate and pipe pieces to make a hinge type hookup. The tractor mount is made from a pattern from a mule drive to frame hookup (just a little beefier), 2 - 2 x 2 angle iron, 1 - 3 x 3 angle iron, 2x2x1/4 sq. tube and 1 1/2 x 1 1/2 angle welded together for the top. Pics are self explanatory. The first pic shows where I mounted the up/down switch (what's the difference if I push a switch with my thumb or push and pull a handle?) The speed is just fine, I don't think it's any slower than hydraulics. It works great for me, but then I'm retired and the only thing that makes me rush to do anything ..............isn't home right now(she's babysitting great-grand daughter) .
Patience is the key to success . The difficult, I'll do today . The impossible, I'll do tomorrow
Old 12-22-2014, 08:06 PM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
Looks good to me! Cheap winches or not I'm sure they will hold up as I don't forsee them getting much use. But when they are in use, oh what a help they will be.
I lost track of what I own a long time ago!
Old 12-22-2014, 08:46 PM
garnold's Avatar
garnold garnold is offline
This really came out great! I like how the front winch setup attaches :-)
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
