Old 01-19-2017, 01:38 PM
cub123's Avatar
cub123 cub123 is offline
Default FEL Brush grapple
Hey guys, I know its been a while since I've had a project, so I thought you would enjoy this. I've wanted to build a grapple for the 149 for some time now, and I finally got around to it the last couple weeks. It mounts by slipping over the top edge of the bucket with a frame going down to the cylinder/loader arm bracket on the bucket with a bolt on each side, so it mounts in about a minute. I still have a few things to finish up, but I wanted to test it first, here are some pictures.
Old 01-19-2017, 02:00 PM
Terry C's Avatar
Terry C Terry C is offline
That is very nice. Best homemade attachment in quite awhile!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 01-19-2017, 02:05 PM
I know where you live, if it's missing some day you know where to find it. LOL. That is way cool!
Old 01-19-2017, 02:48 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
Very nice work! Looks like you found some great uses for it already. I love attachments, especially when there quick on/off!!
Are the tines on the grapple bent flat stock or were they cut from a sheet?
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 01-19-2017, 04:01 PM
That is sweet! Great idea and easy to put on/take off. I'm thinking mister rescue11 better get on the chip as he had that idea for his R bucket.......and so did I.
Old 01-19-2017, 06:22 PM
cub123's Avatar
Thanks!
Hehehehe I don't think it will fit the kubota, lol. Thanks Sam.
Thanks!
Thanks, the tines are made from a set of old new holland mower deck undercarriages that were torched off. I cut the ends off right where the tube brace is in the front, flipped them and welded them back on, worked out pretty well.
Old 01-19-2017, 07:15 PM
ken6x6's Avatar
that repurposed undercarriage worked out great. looks very professional.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 01-19-2017, 07:50 PM
Merk Merk is offline
Do you have a separate hydraulic valve for brush grapple?
Cylinders on grapple look like cylinders off a wide frame/quiet line IH Cub Cadet?
This is something I want to add to my loader build.
Project Uncle Dick
Cub Cadet 70
Old 01-19-2017, 09:20 PM
cub123's Avatar
Thanks
The grapple is powered by the tractor hydraulics. I removed the lift cylinder from the loader tractor and used it on the grapple ( as I have no use for it with the suitcase weights on the back) and ran two lines off the valve to the front of the loader with quick connects, and I had the other cylinder laying around.
Old 01-19-2017, 09:35 PM
Great job Ben!! Glad to see your still at it!
