Old 02-16-2015, 02:08 AM
o---o o---o is offline
Default Tires for sprayer trailer?
I bought a 15 gallon spot sprayer from Rural King that I plan to build a trailer for. At first I was going to use the cheap 10" pneumatic tires but they aren't well known for holding air long. So then I came across some 10" solid rubber tires but they are an inch narrower and I fear they may cut into the yard too much. Then I pondered the 13" pneumatic tires also even though they are a little bit more expensive.
So which of these would you choose as the best tire for a 15 gallon sprayer trailer? I'm open to suggestions as well. After seeing them all, I'm favoring the last one linked.
1. http://www.harborfreight.com/10-inch...ire-30900.html
2. http://www.harborfreight.com/10-inch...ire-35459.html
3. http://www.harborfreight.com/13-in-p...382-10462.html
4. http://www.harborfreight.com/13-inch...ire-37767.html
Old 02-16-2015, 02:26 AM
cubby102's Avatar
cubby102 cubby102 is offline
In my opinion id go with the wider tire if your worried about it hurting the ground...also the 13 inch tire would roll over small ruts..rocks...mounta of dirt... better then the 10" air filled tires seem to handle bumps better and cut in less.
1872 - 60"haban 54" power angle haban blade
'63 Original - restoration project
582 -tiller
147 - leaf duty with bagger.
1811 - Ditch mower
800 - have it just cuz its a 800
Old 02-16-2015, 11:17 AM
You may want to consider one of these.
http://www.northerntool.com/shop/too...ch=118522-1554
We have one that we haul our sprayer around with. Just put a battery in it along with the sprayer and have at it.
Old 02-16-2015, 01:31 PM
I've actually got this one https://www.menards.com/main/p-2255063-c-13262.htm that I picked up on sale for $40 and I thought about using it, but decided to build a trailer instead just because I like building things and my 8 year old daughter loves to help me weld. I've already got the metal laying around to build it with, and I've got a couple sets of 10" air tires that are extras from the kids training wheels for their dirt bikes, but I'm thinking I'd rather have a different kind of tire for the sprayer.
Old 02-16-2015, 02:17 PM
If you are set on making your own trailer, you might consider getting a pair of wheels and tires from the front of a Cub Cadet. I'd bet that some of the guys here have some decent old wheels and tires they would sell pretty cheap.
They would definitely carry the weight and wide tires wouldn't dig into the ground too much.
Old 02-16-2015, 05:42 PM
That's a pretty decent idea, and the bearings would be superior to the Chinese wheel's bearings
Old 02-16-2015, 06:48 PM
john hall's Avatar
Maybe use the entire front axle from any el-cheapo lawn mower. Tire size would be appropriate. You could just tack weld the spindles.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 02-17-2015, 12:03 AM
Yosemite Sam always got great ideas!!! The balloon turf saver tires would be my first choice.
