2186 starting issue
Hello all.
I have a GT2186 that is going on 19 years. For the last couple it’s had an odd starting issue. I was told by the local dealer it would cost about $200 to fix. They said it’s a known problem but yet I can’t find any info on it. Not sure I want to put $200 into fixing because of its age. The issue. It has a good battery, bought last spring and it’s been checked. When I go to start it, I turn the key and all that happens is light on the dash comes on. Everything works though. Safety switches, when started engine runs fine. But to start it, I put jumper cables on it and hook it up to my Jeep. Let the Jeep run for for about 5 minutes and it starts right up. And before you say it’s the battery...I can put a brand new one in and same issue. The dealer said the issue is a low voltage problem that is common on this tractor. Anyone heard of this? |
You need to add a relay to the start circuit. His pictures disappeared due to postimage, but it is a decent explanation.
https://www.onlycubcadets.net/forum/...ad.php?t=38545
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
Thanks!!!!
Hey Shrewcub
Just wanted to thank you again for the wiring. I finally got around to doing it last weekend. Up here in Minnesota, winter just didn't want to leave. The link you supplied works great. Started right up the first time and has worked great since. Thank you!! |
