Old 04-03-2012, 07:13 AM
lmcclinton lmcclinton is offline
Default Rear flood light
My son and I had attached a rear flood light to our previous 1200. Accept it kept draining the battery. Now that we have the 782 we'd like to add the rear flood light to it. What would the proper way be to wire it up and is it possible to have it work only in reverse?
Thanks,
Lee
Old 04-03-2012, 07:50 AM
Inactive Member
Could you show us what your floodlight looks like or give a brand & model number..??
Old 04-03-2012, 05:31 PM
I purchased a 12v utility flood light from tractor supply and attached it to the rear of the tractor. It's a self grounding style.
Thanks,
Lee
Old 04-03-2012, 10:12 PM
PaulS's Avatar
PaulS PaulS is offline
I replaced one tail light on both my 2084 and EricRs 2086 with one each off road fog light. I got tired of no light when blowing snow in the dark . they seem to work great. We mounted them pointing slightly down but man do they light up to the rear. I got the set at Harbor Freight for about $12.
Old 04-04-2012, 10:31 AM
Inactive Member
The 782 had two (2) wiring diagrams, depending on the Chassis Serial Number range (IH or CCC built).
What is your Chassis Serial Number...??
Old 04-04-2012, 09:20 PM
2050594u671758
Thanks,
Lee
Old 04-05-2012, 07:34 AM
Inactive Member
Attached is the hookup diagrams.
You will have to decide on two option.
(A) To wire up independent of tractor lights, connect to the Blue Wire "I" terminal on the Ignition Switch.
(B) To wire up with tractor lights, connect to the Pink Wire "L" terminal on the Ignition Switch.
Old 04-06-2012, 09:21 AM
Thank you Roland for all your help.
Thanks,
Lee
