Old 05-19-2016, 02:50 PM
wham's Avatar
wham wham is offline
Default 1772? Pro's?con's?
Opinions and info. Going to pick it up Saturday!
Cub Cadets - Just Like Lays Potato Chips - No One Can Buy Just One! (Originalx3, 70, 72, 73, 100, 102, 104x2, 105, 124, 149, 1772 Diesel, Z-Force)
Old 05-19-2016, 04:13 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Check the rear axle mounting points for broken/loose bolts and the broken tabs on the front mounting points.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 05-20-2016, 01:52 AM
wham's Avatar
Will do, is that a typical trouble spot for them. Ive only owned NF's and a few WF's so this is new territory for me. I have had a few of the later models and have a 3240 and 2155 now.
Old 05-20-2016, 07:20 AM
MWShaw's Avatar
MWShaw MWShaw is offline
First and foremost replace the fuel lines with new ones and flush out the tank. Check the screen on the fuel shut off petcock, they clog up.
Then change all fluids and filters.
Gear reduction starter, drive shaft and rear end braces were my biggest upgrades.
I did an alternator as well. New battery cables.
Old 05-20-2016, 07:28 AM
MWShaw's Avatar
Yes, that is a trouble spot. Especially if it spent it's life without a 3 point or bagger plate. Without the ends of the frame rails tied together, the frame flexes more, aluminum embosses on the rear end can't take it. They break off.
Its a heavy tractor, likes to have all four wheels on the ground, all the time. The
rougher the terrain, the more flex.
Old 05-20-2016, 09:48 AM
JLM78's Avatar
JLM78 JLM78 is offline
We have two 1572s what are great tractors . Just check the rear end bolts
Old 05-20-2016, 11:53 PM
wham's Avatar
good info, thanks y'all. I only have to go about 92 miles to pick it up and it's supposed to be in good running condition so I'm a little on the excited side, never owned a diesel before.
Tim H.
Old 05-21-2016, 02:54 AM
Tim, where did you find that at?
Old 05-21-2016, 04:53 PM
CubDieselFan's Avatar
I am curious to know too. Tim is about an hour from me. A 1772 for sale close to me and I did not know it. I am slipping. Joking aside, I hope it turns out good for you.
Old 05-23-2016, 02:03 PM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
I would be interested in knowing where you found it as well. I must be slipping
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
