Reverse issues
I just got my first Cub Cadet 1330, and having problems with it backing up. It goes very slow backwards on level ground, but not up hill. Anyone know what I can do to fix this?
Thanks in advance. |
Did you check the Oil level in your rear end unit ??
yup. That sounds about right
I will. Thanks. Well I took alook at it. Took the battery out and fan is all busted up. Any suggestions on a video where I can check the level of fluid and buy a new hydro fan?
I took the battery out and the hydro fan is all busted up. Not sure how to check the fluid level. Anyone know of any videos I can watch to see how it's done?
The Transmission is made by Hydro Gear. I am trying to find out what Model or Series of Hydro Gear Unit that Cub Cadet bought for this series of Lawn Tractors.
Someone correct me if I am wrong. Should be 7" 10 blade CCW fan. Cub part number 931-3080.
They also sell after market on amazon but Cub Cadet one is cheap enough.
I found a tag with numbers
618 3076 3091c342 And I don't see a drain plug |
Here is a link to your Operator Manual....
http://manuals.mtdproducts.com/mtd/S...e=772-4129.pdf Your model number will be on a tag on the left hand side of the pedestal. It should be something like 133-233100 And here is a link to your parts breakdown.... https://www.ccparts.com/cub-cadet-pa...00/ID-4285-225 I believe the transmission is a HydroGear. The transmission may have a reservoir on top for the transmission oil but the pump has it's own self contained fluid system separate from the transmission, you can't check that. Check your belts and linkages for wear and proper adjustment (read the operator manual). If the tractor goes good forward you probably need adjustment. If transmission or pump is toasted it could be fixed but would cost more than the tractor is worth. |
The tractor will go forward and sometimes will go in reverse.
