Old 03-25-2015, 10:55 PM
blee128 blee128 is offline
Default Won't start
I got my motor back together today, and now it won't start and gas is running out of the velocity stack. I was wondering if valve lash could possibly be part of the problem? It's had a cheater can put in, .30 over piston, new springs, ported and polished, a valve job, and added a crank trigger?
Old 03-25-2015, 11:32 PM
Originally Posted by blee128 View Post
.......was wondering if valve lash could possibly be part of the problem .....
Could be.
Might fix the float problem in the carb first though, so the gas stops running out of it.
What's a cheater "can"?
Old 03-26-2015, 12:09 AM
Supposed to be cam I got auto corrected!! Lol
Old 03-26-2015, 12:12 AM
I had to teach my phone "mechanic" words.
Old 03-26-2015, 12:14 AM
everytime i type mow my phone corrects it to now.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 03-27-2015, 08:56 PM
wmortenson wmortenson is offline
I would also check the timing. I had a 12 hp I could not get to run. I ended pulling engine think the timing from the crank to the cam was off. All it ended up being was the points.
Will
proud owner of cub 122,128,70,100,and 682
Old 03-27-2015, 09:03 PM
He has electronic ignition on it....... But that is a possibility.
Old 03-27-2015, 09:33 PM
I've never had the crank trigger but assumed you still had to time it when to fire.
Will
Old 03-27-2015, 10:57 PM
austin8214's Avatar
Gas running out the V-stack is most of the issue in this case. In my opinion.
Old 03-27-2015, 11:09 PM
Agreed.
