Sheet Metal Cutting
Not sure this is the right place for this question.
I need to cut sheet metal and want to get good straight lines. The metal will have a similar gauge as heating ducts. I only need two or three cuts so buying a shear is not a good option. Any ideas? T Thanks
2364i (1541) Kohler ECH23 Power Steering 54" Deck 451 Snow Blower 42" Plow |
I use a welding shop that has a shear. Give them a couple $$$ and everyone is happy.
I put blue painters tape along the cut line, use an angle grinder with a cutoff wheel. Cut along the edge of the tape. Works for me. Helps to have good eyesight and a steady hand.
I used some of these when I put the metal siding on my shop.
http://www.lenoxtools.com/pages/leno...aw-blades.aspx Make sure you use eye protection because they make nasty chips.
I have used a circular saw with a dull blade in backwards to cut very light gauge steel sheet. It's only good for a couple cuts as the blade is junk when you're done. Measure the blade offset and clamp a straight edge to the sheet to keep a straight line. Go slow, eye and ear protection are a must because it is loud and makes a mess. Anything thicker, that you can't crease with your hand, I would use tape and a grinder like ford4150 said.
Bill |
You don't really say what it is your cutting, or how long the cut is. Cause, if it's a 6" cut, not really any need to spend much $$.
Is there something wrong with using tin snips? |
Thanks for the suggestions. I am looking to make two rectangles. Each would be 17 x 6.5 inches. The edges need to be smooth straight and square.
I think I am going to look into welding shop idea from Sam Mac.
If you can clamp it down with a good straight edge on it, you can score heat duct with a utility knife and bend it back and forth a time or two and it will break off.
Your local aluminum siding guys can also cut it for you, probably for a couple of bucks.
If slightly thicker metal and longer, a cutoff blade in a circular saw might work. Set up a straight end to run against. Keep the blade shallow in the metal and it will agree with you more.
Heating duct sheet is usually 26 or 30 ga. A pair of good Wiss snips will cut it easily.
